5 members (32Fordpuchoptop, 55shaker, TUTS 59, panel fan, UtahYork), 74 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#944239 05/19/2013 8:58 AM
I've read the few posts here regarding the camshaft spacer, and some say its not required.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=5466
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=11186
The manual says .001-.005 free play from the thrust plate to the cam... so just press the gear on till I get proper clearance?
The space looks rather thick... will omitting it and pulling the cam forward mess up the oil pump gear meshing, the lobe to lifter seating or any oil hole/bearing flow???
pfarber #944266 05/19/2013 11:28 AM
The cam gear and crank gear need to line up closely. Make sure the crank gear is seated and than line up the cam gear. A little play in the cam is ok. And if you are using an aluminum gear, make sure you heat the gear to expand it a little. Forcing the cam on can peel aluminum away, thus it won't fit properly. You can also cool the cam.
Drew
pfarber #944289 05/19/2013 1:08 PM
Installing the cam gear is not a problem.
The problem is the spacer. Do I need it?
It seems that there was a time when it was not used?
My motor is a 58/59 235.. the manual says to install one.
pfarber #944321 05/19/2013 2:47 PM
All 235's used and need the spacer. It holds the cam in place and sets the correct alignment of the two gears.
My Blog
pfarber #944337 05/19/2013 4:19 PM
So what is the difference in the thrust plates?
Jim Carter lists a thrust plate for the Chevy, but its only one part "Camshaft Thrust Plate Chevrolet 1937-1962".
Right next to it they list a GMC part, with the thrust plate and the spacer "Cameshaft Thrust Plate GMC 1939-1959". Going by what I had on the motor, I got the one piece chevy part.
So I need the part they list as 'GMC'?
Do local auto parts have this? I'm gonna get nailed $10 to ship a $12 part frown
pfarber #944356 05/19/2013 5:15 PM
Napa has them. As well as the spacer.
pfarber #944357 05/19/2013 5:25 PM
On 235's there is a spacer that keeps the gear from being pushed on to far. In affect it sets the clearance between the gear, thrust plate and cam.
The spacer is not essential but it makes it easier to assemble. The earlier Chev's did not use the spacer, you just used a feeler gauge to set the thrust plate clearance when pressing the gear on.
If you want to use a spacer and can't find one PM me.
My Blog
pfarber #944359 05/19/2013 5:37 PM
If I can get one from NAPA I'll use it, otherwise, if I understand this installation correctly just use the thrust plate, and set the thrust plate to camshaft freeplay to .005 by moving the gear on the shaft.
pfarber #944368 05/19/2013 6:25 PM
By Jove I think you got it!
My Blog
pfarber #944993 05/22/2013 10:38 AM
The old spacer was still on the old camshaft.... the woodruff key kept it in place.
When I mic'd the thrust plate, it was .081, the spacer ring was .095... but the timing gear had a bevel... so the resulting clearance was .002.
pfarber #944999 05/22/2013 10:55 AM
Perfict!
My Blog
