2 members (baldeagle, Oswald), 42 guests, and 10 robots.
Topics128,012
Posts1,055,316
Members48,419
#944096 05/18/2013 5:22 PM
can some one tell me how set the choke on my new carb ,, i first got it it was way too high on cold start so i tried to back it off and it came out of the housing,,, so i am trying to get it back in, does the spring piece go in front or behind of piece on the butter fly ???
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944103 05/18/2013 5:40 PM
Y
Y Offline
I just rebuilt one and the only way I can explain the thermostat spring is that it closes the choke as you turn the adjustment clock wise.
Phil
lilrobo #944125 05/18/2013 6:56 PM
ok i understand so cold it would close the butter fly ,,, so what would open the butter fly ?? there is only 1 edge it goes against ??
so in this weather would it close all the way
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944164 05/18/2013 9:40 PM
Y
Y Offline
As it warms up the spring unwinds and gravity takes over, see your idle speed screw/linkage rod to choke.
Phil
lilrobo #944218 05/19/2013 3:41 AM
ok i see the vacuume will pull the flap open , as it heats up ,, i understand now ,i will read and see how far it needs to close when cold ,, i am guessing that cold is cold no matter what temp ,,even after being not running for a day is cold ??
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944228 05/19/2013 7:58 AM
The coil winds up as the warm air goes over it, unless you have an electric choke coil, then the electricity heats the coil and slowly opens it.
lilrobo #944281 05/19/2013 12:51 PM
right now the car has been off for a day or so ,, when i put the spring [censored], in there i need to turn it slowly causing the butter fly flap to close, i would say there is a measurement there that needs to be between the flap and housing ??? i didnt see that in shop manual
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944345 05/19/2013 4:46 PM
turn it enough so it has a little bit of tension to hold the choke closed
lilrobo #944350 05/19/2013 4:52 PM
ok thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
