2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#941981 05/09/2013 10:13 AM
This is one piece that my rig is missing. I have the factory tube that goes around the back of the motor, a rubber hose from that to a 90* cast fitting on the frame, but no filter housing? Does anyone have a picture of what the stock assembly looks like? I need to come up with something.
Crusing in the Passing Lane
I'll look in my parts pile.
That would be cool if you had something. Really interested in seeing what was on it stock?
The oil bath air filter is the same as a 41 Chevy car or truck filter. It mounts on to a casted elbow piece that bolts to the back of the cab, on the cab purch "or what ever that 12" tall plate under the cab at the rear wall is called"? The elbow piece has a hole on top that the filter clamps to, & a hole in front that the rubber tube clamps to. The rubber tube clamps to the down draft carb. & to the elbow. I have an elbow off of my 1939 Chevy COE. I may still have the oil bath filter also. I sold my down draft filter.
Darrell, W.L.
1939 Chevy COE tow truck/My Stubbed toe
1939 Chevy 2 door Sedan
Car chat means talks about Chevy's. All other car makers only build transportation.
I don't work on my cars, I entertain my self in my garage, so my nabor tells me.
I like what your doing with that bed on your COE. Are you saying you do, or don't have a filter assembly? I would be interested in an original. If I cant find one I may just stick a K&N on it and be done.
Straightjacket. here are a few pictures of the air cleaner, this is as good as I can get without taking it off. From what I can recall it looks just like the air cleaner that was on my 52 2 ton.
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
Thanks Jr,
Now I know what it looks like. Is that a dumpbed I spy under there? Volkswagon headlights? I like the small mirror on the door. Looks like the interior is coming along nicely. I notice you have a nice cover for the vacuum wiper switch, this is something else I'm missing.
Yes has a dump bed and vw headlights. After a couple years of looking at the stock headlights I decided they needed to go. The wiper motor cover is stock, I'm missing the passenger side cover.
Jason
1946 GMC COE
I have the passenger side,it's just a flat piece of sheet metal that screws on. If you need it I can get a template for you?
