| | | Forums66 Topics128,096 Posts1,056,496 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94238 01/10/2006 7:19 AM | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | If I add an electric switched aux gas tank switch on the dash, does the sending unit for the guage switch over via the switch or at the electric valve? Right now it switches via a hand valve. Thanks, David | | |
#94239 01/10/2006 7:24 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Every truck I have owned with dual tanks switched the gauge along with the gas tank. You should be able to wire it through the switch or use a relay to switch, or add another switch to the dash so you can check the other tank level without switching the tanks.
#94240 01/10/2006 8:06 PM | | Anonymous Unregistered | | Anonymous Unregistered | I'd keep the hand valve. My truck('84 K10) switches with an electric valve. The switch on the dash does both the tank and the sending unit. Problem is that if you don't use it often, the valve can get sticky and not switch. The sending unit switches leaving you thinking that everything is fine until you run out of gas on the empty tank that you thought you had switched away from. One of these days I'm going to put a manual valve in. Then I will know for sure which tank I'm drawing from. | | |
#94241 01/12/2006 6:21 AM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | my 72 had a hand switch under the driver seat, and when you switched tanks it also switched the gas gauge to the appropriate tank. so it was all contained in the same switch. this was not a production setup, it had been put in to allow the PO to haul his horse trailer lng distances without having to stop for fuel. It held 100 gallons of gasoline, 30 gallon stock and 2 35 gallon auxillary tanks. It got about 12 miles to the gallon so I was able to go 1200 miles on the highway between fillups. It was really nice but it was a depressing half hour when you filed it all the way up and this was back when gas was cheap ($1.50). 300 POSTS, OH YEAH!!!
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
