| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 42 New Guy | | New Guy Joined: Apr 2010 Posts: 42 | hi all,
just rebuilt my Rochester 1 bbl carb for the 48. Was getting ready to put the carb back on and noticed that under the carb is a governor as listed in title... Problem is = it was on upside down and the port marked "to carb" was connected to the vacuum line for the distributor and the port marked "to dist" was connected to the carb...
I had the truck "running" before but just barely, do you think this was put on upside down by previous owner on purpose???
I am thinking I'll install it the way it stated on the unit and report back...I wonder if it was a mistake and the truck never ran right afterwards and that is why I got it at a good price and with such low miles: 16,000.
Curiouser and curiouser...
| | | | | Joined: Apr 2010 Posts: 42 New Guy | | New Guy Joined: Apr 2010 Posts: 42 | didn't start but now I have no spark... | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | I would flip the governor back over then........ try this link: http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0678.htmAlthough it doesn't mention any vacuum lines....so perhaps you have a different beast. Is the governor open or closed with the way it was hooked up.....how about if you hook it up correctly? Does your distributor have ports on it for the air lines to run to and from? My '60 IH has a line for filtered air at the carb to the distributor and then a line to the governor that is integral on the carb. From the description in the manual it sounds like the factory setup does not use air lines or distributor for the governing. Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Apr 2010 Posts: 42 New Guy | | New Guy Joined: Apr 2010 Posts: 42 | Yes, the distr. has vacuum port to advance and that was hooked up to the governor. the carb has a vacuum port near the Idle adjusting screw that goes to the governor... thank you for the link to the manual...still, the governor unit was installed upside down when i got it and the truck did run, but not well...
| | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | Is the only line to the distributor for the vacuum advance? If that is so then it seems to me that the governor would affect the vacuum advance somehow, but that the actual governing is set by an internal spring as the manual describes.
On my '60 IH the distributor actually has lines just for the governing, it uses the rotation of the distributor shaft to affect airflow for the carburetor governor. My truck does not have vacuum advance.
If the governor affects the vacuum advance then installing it incorrectly could very well affect how the truck runs. If I'm understanding the manual correctly, installing it upside down would cause the governor to not function as it relies on airflow(in the correct direction) to close the butterfly. Perhaps the governor was set to kick it at a low enough rpm that a previous owner chose to just disable it to get a higher road speed but did not remove completely.
Tad
| | | | | Joined: Apr 2010 Posts: 42 New Guy | | New Guy Joined: Apr 2010 Posts: 42 | I am now think that is the case, Jungerfrosch...it was installed upside down so it did not function but was kept because to remove it would affect the position of the throttle linkage by lowering the carb an inch and a half and also the carb mounting bolts would be way too long...easier to leave it in place as a spacer... | | |
