0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | My oil pressure on my 3100 with a 235 engine maintains itself around 27lbs while driving, when shifting gears or idling it drops around 12-14 lbs. Is that normal or is there an issue somewhere?
And yes I do have the proper amount of oil in the engine. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | s'OK, maybe even better than usual, nothing wrong
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Hey while we're talking oil pressure in 235's, mine is a '55 fresh rebuild, I was reading 45psi when cruising and around 25 on a idle. This is with an after market S&W guages. Just last week after putting 500 miles on it, it pegs the oil guage at 60. I've obviously checked the oil and everything looks fine, did I loose a sending unit? I drops to 0 when I shut it down. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Just last week after putting 500 miles on it, it pegs the oil guage at 60. I've obviously checked the oil and everything looks fine, did I loose a sending unit? I drops to 0 when I shut it down. Try a different gauge first. It is possible, but unlikely, the relief valve is stuck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | the old timers rule of thumb was you need 10 lbs of oil pressure for every 1,000 rpm. Since you're likely running 8-900 rpm at idle, 8-10 pounds would probably be considered normal for idle. Don't know what "today's" recommendations are, that was just something I heard as a kid. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1953 oil pressure specifications are: 14 psi at 2000 RPM for all (low pressure lubrication system) engines, except Powerglide equipped cars "Specialized four-way method of engine lubrication: direct pressure, metered pressure, pressure stream and splash [cylinder walls and pistons]"45 psi for 235s in Powerglide equipped cars (high pressure lubrication systems) "Full-pressure lubrication: oil from main bearings flows through drilled passages in the crankshaft to the rod bearings. The cylinder walls and pistons are sprayed by oil metered through a hole in the connecting rod journal boss."Does your 235 have hydraulic lifters (Powerglide engine), or mechanical lifters (manual car or truck engine)? What is the engine ID that is pressed into the block to the rear of where the distributor goes into the block? | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | on my 235 new rebuild motor going down the road ( auto power glide ) its 40 or better and when hot ( 80) or so it drops to 10 to 15 just as soon as you touch the gas it jumps to 35 to 40 ,, i was told that was normal
just saying
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'd like to see Pre '68 Dave's comment on that.
Should a rebuilt 1958 235 engine display the oil pressure behavior described by lilrobo?
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i am running 10w 30 oil after it runs for a while it sounds like water draining back down lol i know there is oil up top anyway ,, it only take 3 to 5 lbs to make the light go off , i am thinking about hooking the light back up so i dont keep looking it lol
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Most 235's I have seen in good shape have 30-35 max when warm and half that at idle. If it is going much above that when warm I would suspect the relief valve in the pump is hanging up.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | Most 235's I have seen in good shape have 30-35 max when warm and half that at idle. If it is going much above that when warm I would suspect the relief valve in the pump is hanging up. Dave, my new rebuild(still running break in oil) keeps my gauge pegged at 30. When I can afford it I want to go to the Jim Carter rebuilt gauge cluster with the increased oil pressure gauge and the higher temp gauge but for now should I be concerned about the higher pressure? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you saying even at an idle it is pegged? That could be a problem. If it is only when revved up that you peg the gauge then do problem. I have never seen or heard of any problem with running the 30 lb gauge pegged. If you want to know what the actual max pressure your engine is putting out you can hook up a temporary mechanical gauge.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 51 | I'm taking the truck to my builder tomorrow to be timed so I'll bring the oil pressure issue up. My builder knows his stuff...Dragmaster was really big in the 50's and 60's and they did all our marine engines when I worked the boatyard in the 70's. Dode has been around the block a few times(and down the strip many, many times). | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I have a 216 converted to full pressure, with a 54 235 oil pump, I get around 32 psi while running, and about 23 psi idling. | | |
