1 members (Hush), 73 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
V
V Offline
Can this be caused by overfilling the coolant, or do I have a blown head gasket or cracked block? The radiator was nowhere full when it started coming out - I was filling it up. When I started up the engine it started pouring out of the valve cover.
How much coolant does the whole system (with heater) use on a 235?
The coolant capacity is different for different years and sizes of trucks/radiators.
14-16 qts in 1941
Take off the valve cover to see where the leak is.
V
V Offline
It's coming out from where the valves come up thru the head. The engine is a 1956 235 from what I can see.
sounds like a cracked head to me ohwell
that head is a flower pot
Didn't leave a head bolt or some other bolt out that goes into the water jacket? If not, then the others are likely right.
V
V Offline
Having trouble getting the head off. I've been working my way around the perimeter with a putty knife then small screwdriver to break the seal. Then I tried putting a crowbar in several of the ports and prying but no luck. Any ideas?
V
V Offline
Do any or the rocker shaft bolts hold the head on? I didn't think they did so I left them alone.
Make sure you have all 18 head bolts out.
Rocker bolts do not need to come out, it just makes assembly easier, and easier to get the three center head bolts.
My Blog
Never hammer or over pry on anything. And make sure every bolt is out.
V
V Offline
I'm only counting 16 head bolts: 8 inside the valve cover and 8 on the outside of the valve cover next to the intake man. I even looked under the side cover and took off the rocker arm shaft.
V
V Offline
I found the 2 bolts I missed
V
V Offline
Got the head off. Looks like it's cracked around two of the valve seats that I can see so far.
