| | | Forums66 Topics128,032 Posts1,055,517 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | We've got a stuck check-ball in our carburetor float bowl. It's at the bottom of the accelerator pump well. There is 1 port and 1 check-ball at the bottom.
Of the two carb float bowls we have both check balls are stuck. This seems to be common.
What will happen to engine runability if the ball is jammed? We are having stalling issues when warm.
Thanks, J&K | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It will not run well and can be a contributor to your stalling problem. Spray some carb cleaner in the holes. They should come out by tapping against a block of wood. You could also blow them out with air. Just be care full where they go. Fred
