| | | Forums66 Topics128,012 Posts1,055,313 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | 1948 3100. I am installing new window wipes. The inside is no problem but I am having trouble with the outside wipe. My new rubber piece is triangular shaped. I did not seem to be able to get it into the slot with a screwdriver of putty knife. The old wipe seemed to be rounded in the track. Does anyone have a tip for installing these wipes. Thanks
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | There are two different ones I have come acrossed. The ones you have & the correct ones that actually work & slide right in. I thought I had bought both sets at the same place but then I remembered I had bought the right ones from some place back east or mid west but can't remember where. I will ponder on this as I need to get a set for my 1948 as well. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Probably Steele Rubber Products. | | |
