7 members (walterhvogel, Jman, Tom McGrath, UtahYork, Materman, Rich'sToys, Wally / Montana),
107
Mod | | | Forums66 Topics128,035 Posts1,055,557 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 87 | I have 2 pushrods keeping my 235 head from seatting flush. Ideas?
I have a 46 pu with a 235 & I got a fairly clean looking one off craigslist which wouldnt turn over by hand and most likely will go into a 5 wondow 1950 pu I have.
Ive read most the engine threads on here amd youtube videos including the carbkings catn vids
I used marvel mystery oil etc and got her freedup. Moved the pistons by hand to see if that would help. Pulling the head wasnt bad as a one person job but setting it back on has its chachallenges. Suggestions on that besides gey a helper?
Take it easy on my hillbilly self ~ new this and not.much help local car club etc
Respectfully Dean
1938 Chevy 1/2 ton Pickup 1940 Chevy 3/4 KD Pickup 1946 Chevy 3/4 ton pickup 1940 Chevy 1/2 KC Pickup 1939 Chevy 1.5 Truck
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Sorry not much help on the push rods, but a come-along and a chain will take the weight if you have something to suspend from... like a shade tree?
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the pushrods aren't in the way of the head, do you mean you have stuck valves? that is the only way I can think it would affect the head setting right | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year 235 (year of head and year of block)? Did you follow the procedure after "Installation"? You put the head on and torque it, Then, put the push rods in place, Then, put the rocker arm assembly in place (over the push rods), Then tighten down the rocker arm assembly, moving from bolt to bolt? | | | | | Joined: Dec 2008 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 87 |
