1 members (Otto Skorzeny), 81 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
#941237 05/06/2013 12:41 PM
I have 2 pushrods keeping my 235 head from seatting flush. Ideas?
I have a 46 pu with a 235 & I got a fairly clean looking one off craigslist which wouldnt turn over by hand and most likely will go into a 5 wondow 1950 pu I have.
Ive read most the engine threads on here amd youtube videos including the carbkings catn vids
I used marvel mystery oil etc and got her freedup. Moved the pistons by hand to see if that would help. Pulling the head wasnt bad as a one person job but setting it back on has its chachallenges. Suggestions on that besides gey a helper?
Take it easy on my hillbilly self ~ new this and not.much help local car club etc
Respectfully
Dean
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
Sorry not much help on the push rods, but a come-along and a chain will take the weight if you have something to suspend from... like a shade tree? eeeek
Give me ambiguity
or give me something else
the pushrods aren't in the way of the head, do you mean you have stuck valves?
that is the only way I can think it would affect the head setting right
What year 235 (year of head and year of block)?
Did you follow the procedure after "Installation"?
You put the head on and torque it,
Then, put the push rods in place,
Then, put the rocker arm assembly in place (over the push rods),
Then tighten down the rocker arm assembly, moving from bolt to bolt?
Thanks for the info.
