3 members (Otto Skorzeny, TexasA&M48Truck, 1 invisible), 63 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
I'm putting in new wiring harness, and want to know on dimmer switch which of the bottom two connectors is high beams, which one for low beams. Of course the top connector is for battery. thanks
headlamp upper beam-center post
Riding in the Passing Lane
The center is the hot lead. It doesn't matter which of the other ones go to the high or low.
1972 Chevy c10 Cheyenne Super
curious what year is your truck and which harness did you get? I am leaning toward the $149 harness from classic.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
...click...
Above is from the assembly manual.
It shows center upper beam,
Bottom lower beam,
If is not your year/type switch a quick test with a continuity meter will determine your hot post
Good luck
Ex Hall Monitor
Ex Hall Monitor
I wonder when they changed? The center lug is the hot lead on my '38.
<CLICK>
Not sure,
His earlier post deal with 50 or 51
1950 wiring diagram makes it look like center is hot ... as does every other year diagram .... should be obvious from the construction of the switch, the same 1936-1954, after which they went to a plug in type that's 'fool proof' wink
I agree
...click...
smile
Ive been doing it for 60 years & have never found one different then that. The headlight sealed beam conectors are not concentric likev that. It can fool you.
