| | | Forums66 Topics128,122 Posts1,056,331 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | I'm at a loss on this one. What appears to be oil is leaking from the steering column, in the interior, about half way up the column. I'm trying to get some photos posted.
Any ideas?
1955 GMC 100 Series 2
| | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | http://m.flickr.com/#/photos/71945287@N03/8707859819/
http://m.flickr.com/#/photos/71945287@N03/8707857785/
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't see any oil, but I see a big hole [in this picture] that should NOT be there .... only place oil could be coming from up there is if someone poured oil into the upper mast bearing, like maybe it was grinding and acting dry - meaning it needs to be replaced, it should not be lubricated - and the signal wires should have a little cover over that squarish exit held on with one screw Bill | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you sure the oil gauge or line is not dripping down on the column?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks for both the replies. I'm at a loss to what is going on a d where the oil is coming from. I just checked the oil pressure gauge again and it's dry. Ram the truck and nothing coming out of the gauge. I will take some better photos in the morning and post them up.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Might be a good idea to check the steering box and see if its overfilled, see if its got grease in it or maybe someone put oil in it? You could also pull the steering wheel and see of someone over did it and put lots of oil or grease in from the top? Couple ideas..... | | |
