| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Using the original parking brake lever with an e-brake bracket that mounts to the T5; one of the mounting holes was filled and then re-drilled in order to mount the lever to the bracket. The 2" bolts will be cut to fit and the bottom of the lever will have to be shaved. In the end, it has came together quite well. Bread . pic . pic . pic . pic
