Seon,
I think joker has ESP...he knows I can't resist giving bum info!
My approach to this question would be a little different. You don't have the BCM, so some of the wires might not be relevant without it. I would make a list of what you need...left turn, right turn, brake, ignition, horn etc. Then figure out what functions the new column will provide.
Use a VOM and find the function of each wire coming out of the column. Match those with the functions you require and you're home free.
I'm assuming you are going to use the column ignition switch and not the stock dash unit. This will require some invention, not hooking this color to that color. The new column has a flasher position on it...the old rig had no flashers (?)..more creativity.
I guess what I am saying is you won't find a wiring diagram that will mate the two systems.
You probably will find a diagram that identifies the wires by color that exit the column, but without the BCM they might not perform the function you want. This might not be the answer you wanted, and it might not be THE answer, but it's the best I can do on short notice. Good luck.
Stuart
