5 members (klhansen, dt235sd, Hanks custodian, mick53, Otto Skorzeny), 48 guests, and 3 robots.
Topics128,180
Posts1,057,158
Members48,464
#940056 05/01/2013 12:23 PM
Need some advice on removing the old spring bushings whats the best way without a press Thanks for any advice.
what year and GVW?
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
1954 half ton 3100
Here is a Tech Tip for a bushing puller.
Mine last set of bushings were so tight that the bolts in that design broke.
Two other options are in this post/thread.
Unless the threads are really worn bad inside the bushing I use a length of 5/8"-11 all thread.
Simply screw the all thread into the bushing. Then slid a piece of pipe with a 1" ID the length of the bushing or longer down the all thread. Then a washer, then a nut.
Tighten the nut and the bushing will be pulled into the pipe.
This basic set up works for pulling the new bushing in also except you do not need the pipe.
My Blog
Thanks for all the help 1" pipe and the all thread worked like a charm. MEMBERS OF stovebolt come through again.
I have added a shackle bushing step by step removal and installation to My Blog if anyone is interested.
My Blog
Great Blog Dave...thanks for the link and the data
VERY COOL
Glad you enjoyed it!
My Blog
