3 members (Sjm, Forty9, 1 invisible),
90
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 7 New Guy | | New Guy Joined: Mar 2013 Posts: 7 | Can anyone tell me what size tires the factory put on a 49 1/2 ton panel? | | | | | Joined: Mar 2013 Posts: 7 New Guy | | New Guy Joined: Mar 2013 Posts: 7 | Thank you Gabster. My 49 panel has P255/70R15 tires on it. I thought the tires were too wide but had no idea they were too small to boot. Are there any pros or cons on returning it to the correct tire and wheel size? Do the tire and wheel size make enough difference that I should switch them? There is no rubbing of the tires to the body right now but I think if I took a hard right or left turn and hit a dip in the road I think the front tires would rub on the fender in the direction of the turn but there is no sign of this on the current tires. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | advantage of correct size tires is your speedo and odometer will be more accurate, you'll have lower RPM at a given speed, and you won't wear the side off your pitman arm with hard left turns as is possible with wider tires
Bill | | |
