6 members (Jays58, BC59, KEVINSKI, tricordati, Otto Skorzeny, Gazz), 111 guests, and 4 robots.
Topics128,095
Posts1,056,468
Members48,444
V
V Offline
Have a 1945 GMC 1/2 ton. Parked it last fall all the lights worked. Started it up last week, checking lights noticed that signal lights stopped blinking with head lights on. Have made the park lights into signal lights. Have 6volt system,led 6volt flasher,6 volt led bulbs in rear lights, with a 6volt led third brake light. Has anyone any ideas what is wrong?
There is no global warming in Alberta Canada.
Check your ground connections. Check the flasher too.
Just out of interest: negative ground (earth) or positive ground (earth) electrical system?
V
V Offline
Positive ground
Had a similar issue with my system last year ( 12v. / LED )
Turned out to be a bad flasher unit.
1940 Chevy KC 1/2-Ton
