0 members (), 106 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
I recently obtained a 1951 gmc long bed. I would like to change the differential oil and transmission oil. I would like to know what weight oils to put in them? Thanks for you help in advance.
Just head to your FLAPS or local farm store and pick up 75w90
and that will take care of all your transmissing and axle needs.
That's all that is used in many over the road fleet trucks. I'd
stay away from the more expensive synthetics especially if it's an SM420 transmission.
Denny G
Denny G
Sandwich, IL
Thanks for the advice. Now, Isee the drain plug on the transmission, but where is the fill plug. By the way it is a 4 speed.
Thanks for the advice. I have read both manuals. Neither show where to fill the transmission.
I have never had a 4 sp in my truck, but I seem to remember someone saying to take the shifter out and fill from there. It is easier when trans is in the truck already.
I would think that the trans is no different than the 3sp and has a plug on the side, fill to the point where oil just reaches the bottom of the plug hole.
Tommy
59 apache 1/2t
261 short stepside
Half way up the right side of the transmission you will see a
pipe plug. Fill with oil till you can touch it when you poke
your pinky finger thru the hole.
If you're just topping off the oil a squeeze bottle such that
the oil comes in works. If you've drained it and need to add
the 6 pints that it holds then it is faster to pull the shifter
as Tom mentioned. I've filled an empty 4speed from the fill
hole on the side before but it takes a half hour to do it
that way. Then again, it takes at least a half hour to pull back
the floor mat, remove the transmission cover and pull the stick
and put it all back together.
http://www.pbase.com/dennygraham/image/137678406
Denny G.
Denny G
Sandwich, IL
Thanks. Can I use 80w90 GL5 in both the rear end and transmission?
Yep.
dg
Denny G
Sandwich, IL
ok, drained my 4 speed transmission today. It is bolted to a 235 Chevy. Oil was thick and black. it was ell above the fill plug on the side. I pulled the side cover of since I could not remove the drain plug. Refilled through side plug with 80w90 gear oil. Want to make sure I'm not missing something. Is there any way to figure out what transmission I have?
In the same vain when I was underneath, it looks like there is a fill plug where the drive shave goes into the differential. Should it be filled with 80w90?
