1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 112 | Two mornings now only in the beginning when the truck is cold and put in neutral to start the new TOB chirps ,squeals and then no more noise.once it is warm or even the second start of the day no problem.no shift problems and it drives well with no chirping.Should i grease it some more or put STP on or??? FEED BACK ANYONE. THANKS | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | If you put a light coat of grease on the bearing surface and inside where it slides on the bearing retainer housing that should be sufficient. Go back and check your clutch adjustment free travel. Fred
