8 members (Ponchogl, TexasJim50, Gdads51, JW51, dt235sd, 3 invisible), 73 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
#938535 04/25/2013 5:16 PM
Dear friends,
At this time I have invest more than 3 hours on the web tryn to find the hubcaps for my 1958 3/4 ton 4x4 chevy truck.
have the split rim 17".
Does anybody can give me a hand?
I preffer to buy the new ones, *
thanks,
Alfonso
the 3/4 & 1T caps appear to be discontinued Alfonso, you'll need to be looking for used, try a post in the parts wanted - and maybe try an inquiry to Jim Carter who have some used parts
J M Offline
If my memory serves me right, the 4x4's did not have hubcaps back then. I had to order hubcaps for my 1973 1/2 ton 4x4 and cut the hole in the center for the hub to stick out.
3/4 ton trucks did have hubcaps, but not 4x4's
We will see if someone remembers better then I do.
Good luck
Jim
Try http://www.thewheelsmith.net
They list hubcaps for 1958 pu, and might be able to make you the rears for the floating axle. Good luck
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I looked for about two months for my 55.2 3/4 ton then posted a wanted ad here. Two days later a fellow Stovebolte offered me a decent set of used hubcaps that I sandblasted and repainted. Never did find a new set and still look from time to time.
