5 members (78buckshot, ShopRag, stlcardinalsguy, Ponchogl, moparguy), 79 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
b10
Offline
Two mornings now only in the beginning when the truck is cold and put in neutral to start the new TOB chirps ,squeals and then no more noise.once it is warm or even the second start of the day no problem.no shift problems and it drives well with no chirping.Should i grease it some more or put STP on or??? FEED BACK ANYONE. THANKS
If you put a light coat of grease on the bearing surface and inside where it slides on the bearing retainer housing that should be sufficient. Go back and check your clutch adjustment free travel.
Fred
