| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 112 Shop Shark | | Shop Shark Joined: May 2007 Posts: 112 | Dear friends, At this time I have invest more than 3 hours on the web tryn to find the hubcaps for my 1958 3/4 ton 4x4 chevy truck. have the split rim 17". Does anybody can give me a hand? I preffer to buy the new ones, * thanks, Alfonso
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 3/4 & 1T caps appear to be discontinued Alfonso, you'll need to be looking for used, try a post in the parts wanted - and maybe try an inquiry to Jim Carter who have some used parts Bill | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | If my memory serves me right, the 4x4's did not have hubcaps back then. I had to order hubcaps for my 1973 1/2 ton 4x4 and cut the hole in the center for the hub to stick out. 3/4 ton trucks did have hubcaps, but not 4x4's We will see if someone remembers better then I do. Good luck Jim
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Try http://www.thewheelsmith.netThey list hubcaps for 1958 pu, and might be able to make you the rears for the floating axle. Good luck Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | I looked for about two months for my 55.2 3/4 ton then posted a wanted ad here. Two days later a fellow Stovebolte offered me a decent set of used hubcaps that I sandblasted and repainted. Never did find a new set and still look from time to time.
