1 members (1 invisible), 368 guests, and 5 robots.
Topics128,162
Posts1,057,043
Members48,463
#938510 04/25/2013 2:40 PM
So as I was cutting and buffing my hood I noticed a flaw - it looks like the gun may have spit a high concentration of metal flake about the size of a finger tip. Needless to say I ain't leavin it that way.
What is the best choice scuff and reshoot? or try to spot fix it? I have clearcoat on as well (hence the Cut and Buff)
Sand with 600 or 800.
Re shoot the panel.
Its metal flake.
Give me ambiguity
or give me something else
I must be going blind - cannot believe I did not notice it when I shot it. Only after wet sanding it all with 1500 and then 2000 and then buffing did I see it.
that is about 30 hours down the tube.
gotta love it!
Wondering if Magnets could have been the cause. I had the hood covered with a plastic drop cloth after it was all primed (for winter) that was held in place with a couple magnets.
Is it possible that the metal got magnetized just enough to draw a higher concentration of metallic flake in that spot?
The metal flake is probably aluminum which is a non-ferrous metal.
Next to impossible to spot metalic painted panels, as mentioned
you're better off shooting the whole panel if you want it to look
even.
DG
Denny G
Sandwich, IL
think i will pick up some trizact 1500/3000 discs or Norton Ice to see if that speeds up the cutting of the clear.
Cutting happens with 4-8 hundred grit. Above that your just polishing.
Give me ambiguity
