4 members (WICruiser, Gray_Ghost, Bill Hanlon, Nick in Manitou), 125 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
#937634 04/22/2013 1:32 PM
I'm working on a 1950 3600 that is very tired. I want to update the brakes to Bendix, and picked up some '53 3/4 ton axles. The '53 front has new kingpins, but the rear doesn't look like anything special. Should I just swap the backing plates outward? Or should I swap in the whole axles? Will I run into any issues swapping the whole axles? I also can't find any tapered wheel bearing conversions for this, do they exist? Last question (for now), are there any write-ups out there for updating steering/tie rods? I would like to do the modern ball joint conversion as well. Thanks, Ken
I tried searching, but I didn't see anyone swapping in the entire front axle. I also don't know much about upgrading the steering compenents. I would like it to handle the best it can with the original front axle (modern tie rod ends, changing any geometry, larger tie rod, wheel bearings, and a sway bar). If there are any step-by-steps or how-tos I'd be interested.
3B Offline
Hy playinsafe44, could you tell us the year of the truck you're asking about please.
I am working on an original 1950 Chevy 3600. I have a 1953 Chevy 3600 front (new kingpins) and rear axle.
3B Offline
Hy playinsafe44, as far as I know the axles should be a bolt in swap. I don't think there was a sway bar for a 3600, but that doesn't mean that one couldn't be adapted. There should be some threads on here about converting to "modern" tie rod ends, hope that helps.
You can swap the spindles out, but I believe it's easier to just swap the backing plates and drums.
As far as roller bearings go, if your are sticking with drum brakes, the oem ball bearings are fine. I bought a set of MBS Rollers from Chev's of the 40's a few years ago. I'm not sure if they handle them anymore though.
My bearings: http://s1074.photobucket.com/user/w...&_suid=13668427020380552488455113892
The 1/2 ton sway bar is a direct fit for the 3/4 tons also.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
i'm thinking about swaping my front axle for a independant set up from a newer 1-ton van. it's 8 lug and should be the correct bolt pattern if before 1999. i have read that it will bolt right in if you narrow it about 1.5-2 inches. you then need to mount the steering box onto the frame. i'm not sure yet about upgrading the rear brakes. i'd like to keep the origional 8 lug rear and upgrade to newer self adjusting brakes but i'm still researching this change.
