1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | I'm working on a 1950 3600 that is very tired. I want to update the brakes to Bendix, and picked up some '53 3/4 ton axles. The '53 front has new kingpins, but the rear doesn't look like anything special. Should I just swap the backing plates outward? Or should I swap in the whole axles? Will I run into any issues swapping the whole axles? I also can't find any tapered wheel bearing conversions for this, do they exist? Last question (for now), are there any write-ups out there for updating steering/tie rods? I would like to do the modern ball joint conversion as well. Thanks, Ken | | | | | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | I tried searching, but I didn't see anyone swapping in the entire front axle. I also don't know much about upgrading the steering compenents. I would like it to handle the best it can with the original front axle (modern tie rod ends, changing any geometry, larger tie rod, wheel bearings, and a sway bar). If there are any step-by-steps or how-tos I'd be interested. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy playinsafe44, could you tell us the year of the truck you're asking about please. | | | | | Joined: Feb 2007 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 14 | I am working on an original 1950 Chevy 3600. I have a 1953 Chevy 3600 front (new kingpins) and rear axle. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy playinsafe44, as far as I know the axles should be a bolt in swap. I don't think there was a sway bar for a 3600, but that doesn't mean that one couldn't be adapted. There should be some threads on here about converting to "modern" tie rod ends, hope that helps. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | You can swap the spindles out, but I believe it's easier to just swap the backing plates and drums. As far as roller bearings go, if your are sticking with drum brakes, the oem ball bearings are fine. I bought a set of MBS Rollers from Chev's of the 40's a few years ago. I'm not sure if they handle them anymore though. My bearings: http://s1074.photobucket.com/user/w...&_suid=13668427020380552488455113892The 1/2 ton sway bar is a direct fit for the 3/4 tons also. | | | | | Joined: Dec 2006 Posts: 9 New Guy | | New Guy Joined: Dec 2006 Posts: 9 | i'm thinking about swaping my front axle for a independant set up from a newer 1-ton van. it's 8 lug and should be the correct bolt pattern if before 1999. i have read that it will bolt right in if you narrow it about 1.5-2 inches. you then need to mount the steering box onto the frame. i'm not sure yet about upgrading the rear brakes. i'd like to keep the origional 8 lug rear and upgrade to newer self adjusting brakes but i'm still researching this change. | | |
