3 members (Napco Man, dunfire, 68ironhead), 214 guests, and 2 robots.
Topics128,081
Posts1,055,955
Members48,430
#919924 02/14/2013 9:00 PM
I am moving my gas tank to under the bed behind the rear end. Does anyone know if a tank for the 47 & up trucks would fit? I would like something low profile so it wouldn't be readily noticeable.
rpinnt90 #920214 02/16/2013 7:24 AM
Id like to know that also, because I wanna move my gas tank to the back of my 46
hoozat #920423 02/17/2013 8:00 AM
Moderated
Moderated
I installed a low profile tank in front of the third member 18 gallon aluminum tank, Nice pictures, did you redrill the steel rims
rpinnt90 #920592 02/17/2013 6:08 PM
no, I have an s-10 rear under the back end and I switched the front to 5 lug
rpinnt90 #920693 02/18/2013 6:56 AM
I used a 49-52 chevy car poly tank I believe it came from Chevy of the 40's.
rpinnt90 #921911 02/22/2013 7:45 AM
the 35-6 truck should fit holds about 17 gal cost about $225 they are about 36x17x7
rpinnt90 #926028 03/09/2013 1:36 PM
I went with Gman's advice and used the 49 chevy poly tank, got it installed last night. It tucks under the rear crossmember nicely.
rpinnt90 #927236 03/13/2013 5:43 PM
Fits well doesn't it? Post pictures of progress.
rpinnt90 #938115 04/23/2013 11:05 PM
Any pics of the tank mounted?
JCKN #938415 04/25/2013 2:58 AM
I got a few photos of the gas tank install.
http://s1202.photobucket.com/user/rpinnt/library/
rpinnt90 #938606 04/25/2013 10:02 PM
Thank fit's in there nicely. did you get it from chevys of the 40's? Do you have a link to the one you got?
rpinnt90 #938665 04/26/2013 1:08 AM
I got it from Tanks Inc in Iowa. Actually ordered two different ones, as I was not sure which would work better, and returned the one I didn't need. They were great to work with.
http://www.tanksinc.com/index.cfm/p...ory_id=63/home_id=-1/mode=prod/prd43.htm
