| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | can someone tell me how many positions a 1953 3100 ignition switch has. seems like mine has off and on. should there be one for accessorey. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no accessory position until the V8 years, yours is correct
Bill | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | If it is the same as a "52". straight up is on. Key to the left is off and to the right is off. Either right or left, I think left, the key can be removed and still will be able to turn to the ON position. Turn the other way, I think right, remove the key and the ignition switch is locked.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | You've got it correct, Bart. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | the standard ignition has only two positions left-off, straight-on. both terminals are hot in the on position. ...pic... ...pic... this is the type of ignition that lets you operate without the key ...pic... here are the positions from Brad Allens site ...pic... you would not want to leave your ignition on very long without running, this could damage your coil good luck | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Ok, Just thought it was odd. The reason it came to my attention was when i pushed down on the foot starter it cranked over, i looked at the switch and it was in the off position. It's not supposed to do that is it. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy basham, you can activate the foot starter anytime you want, key in off, key in on, truck in gear, truck in neutral. If your truck has been converted to twelve volts, and has a resistor bypass circuit the engine may even try to start, but it will quit when you release the starter pedal, hope that helps. | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | ok, that does help. I just figured i had a wire in the wrong place. I was going to go out tonight and try to retrace a few of them. Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | basham, there's a couple reasons it's important to understand how the foot start/ignition works - one is the starter is always "hot" because the battery connects directly to it, the foot pedal is a mechanical switch that uses that power to activate it at any time, so when you're fiddling under the hood, some 'helper' sitting in the truck can cause the engine to start cranking, stay aware!! the other is that it's real easy to 'hot wire' by simply putting a jumper from the battery to the coil, push the pedal and make away with the truck  the ignition switch simply completes that circuit from the battery to the coil, and any accessories inside - the simpler times before anti-theft devices  Bill | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | This is all good info to know. I've never driven the truck nor did it run when i bought it. So i have no experience with one of these. I restored a 52 styleline several yrs ago but it was an automatic with push button start on the dash. So many things were different. Thanks again for the info. | | |
