| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Bought a 56 temp. sending unit from classic parts. With a 160 thermostat the gauge reads in the middle, with a 180 thermostat it reads all the way over to the hot side(needle not buried). Does anybody know of a part# of a temp. sender from a local parts store, that would be more accurate?
TIA.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there isn't any difference among senders if they're not defective, but NAPA #TS6469 is what you want ... the "problem" is the gauge, they're not precision instruments, just meant to warn of sudden deviation from "normal" - you need to check actual temps around the rad in and out to compare so you know what the gauge is telling you - if it's reading too close to the top when things are right you might try carefully bending the needle back a bit
Bill | | |
