| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 11 New Guy | | New Guy Joined: Sep 2005 Posts: 11 | Anyone know of a decent way of testing the electric temp gauge for the gauge cluster? I have a new temp sender, but have not had good luck in wiring it to the gauge and testing if the gauge works. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the power lead is attached to the correct terminal [one toward driver side], grounding the other terminal [pass side] or the wire at the sender should make the gauge move .... the sender is a variable resistance that changes as it gets hotter - make sure you do NOT use any thread sealer or teflon on the sender, it needs to have a good ground to the engine .... and welcome to the garage  Bill | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | 52 pickup, Another welcome. As a new guy you need to learn to use the search feature in the header. If you type in temp. or temperature gauge you will get a number of posts which deal with trouble shooting, repair, and calibration of this gauge. As a sidebar, fuel and temp gauges (balanced coil type) work the same way. The senders are nothing but variable resistors. As the fuel level/temp goes up, the resistance goes down (usually). A number of gearheads lurk here just waiting to pounce on a truck/car problem you have.
| | | | | Joined: Sep 2005 Posts: 11 New Guy | | New Guy Joined: Sep 2005 Posts: 11 | Thanks for the tutorial Shop Shark. | | |
