5 members (JW51, Gdads51, John L., DadsFirstPickup, 3B), 104 guests, and 1 robot.
Topics128,118
Posts1,056,305
Members48,439
#936125 04/16/2013 11:14 AM
I'm building a 51 3100. The engine is an ls-1. I purchased the fuel tank that goes underneath the bed. My question is what fuel pump for the FI/LS-1.I'm being told that the tank needs a baffle and sump? My tank has neither. What are my options? I know the AERO makes a pump/baffle combo for about $600.00. it requires cutting a hole in the tank to put this in. outside of cutting a whole what else?
Sounds like a lot of $$$ for a fuel pump ?
Have a look at www.tanksinc.com
They have a number of setups that might work.
1940 Chevy KC 1/2-Ton
Probably should have thread moved to the HiPo section. You'll get more response there. I know that modern fuel injection systems have a need for a special fuel pump and tank along with return lines. I'd research the requirements first and then see what it takes to make your tank work or if it would be more cost effective to get a different tank.
It's probably more cost-effective to get a tank meant for injection. You'll be best to do some research via google or talk to the guys on http://ls1tech.com/forums/ and see what they have to say.
My 46 GMC on Photobucket
