1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Just wondering if anyone would know the specs and procedure to adjust valve lash on a '62 235 with hydraulic lifters, this would have to be done cold as my carbs aren't finished yet, thanks in advance. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | I did min in firing order i took the slack out and give it 1full turn down, , now after you get it started do them again after its real hot after driving it or normal temp i lowered the idel as low as i could and backed each one off untill i heard tick and give it 1 full turn again mine right on even after setting for a day or so, ,, need any more help shoot me a pm or repost, , i have gotten qlot of help from here and glad to help someone else
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | OK, I need to know how you can adjust a rocker that pivots when running and use a screwdriver to lash it down, this is not a small block chevy that rocker studs are fixed. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It is a bit messy and you have to have the idle a way down low. The big problem is with the low idle, causing a miss while adjusting a valve can cause it to stall. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | There is a special tool for that I have for my 270... is allows one hand loosen the lock nut and adjust the screw while the other hand holds a feeler. Its a marvelous contraption: http://www.tm9-801.com/searchTM9/tm9_pages/230.pdf | | |
