6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
#935710 04/14/2013 5:42 PM
I'm having some trouble finding a lower radiator hose. I'm working on a 53 1/2 ton with 261 using an aluminum american eagle radiator with 1 3/4 lower hose neck. Anyone out there using this setup. I need a radiator hose number. I've been through some of the local parts shops looking at all there hoses with no luck. Don't think a flex hose will work.
basham #935713 04/14/2013 6:08 PM
Maybe find a short hose that fits the water pump and another that fits the radiator, then go to a plumbing store and get a copper elbow to connect the 2 hoses. Maybe a street elbow or regular and you can get 45 or 90 bends. A flex hose is not good especially with an aluminum radiator, they can bend the neck from the pressure and generally they look like a patch job when you use them....my opinion anyway.
basham #935735 04/14/2013 7:24 PM
if you have 2 different size necks, get a hose the larger size to suit the routing and a reducer fitting[s] to fit in one end to step it down, and don't let some counter jockey tell you there is no such animal, I've had to use them on a project
Flxible #935743 04/14/2013 7:39 PM
I thought about an elbow. I have heard about a reducer but have never used one. Sounds like 2 good suggestions if i can't find the right hose. I have a couple more parts stores to check out first. Thanks guys.
basham #935748 04/14/2013 8:09 PM
You might look into Dayco #70452 lower hose it has 11/2" on eng. side and 13/4" on rad side. 14" long and the right shape.
root #935768 04/14/2013 9:34 PM
That looks like it will work. I'll call around tomorrow. Thanks.
Flxible #936648 04/18/2013 12:31 PM
good call
I had to go to 3 parts stores to find one that could help, reducer works great
basham #936658 04/18/2013 1:33 PM
thumbs_up my local NAPA has a good collection of paper catalogs and some guys who know how to use them, a lot of stuff that isn't in the computer is available for unusual & non-OEM applications
Flxible #936738 04/18/2013 7:54 PM
nobody had that hose. said they could order it. i went to napa and found what i think might be a better hose. i'll find the number on it and post it. but i do think that dayco hose would have worked fine. thanks.
