1 members (SlimSix),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I'm having some trouble finding a lower radiator hose. I'm working on a 53 1/2 ton with 261 using an aluminum american eagle radiator with 1 3/4 lower hose neck. Anyone out there using this setup. I need a radiator hose number. I've been through some of the local parts shops looking at all there hoses with no luck. Don't think a flex hose will work. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Maybe find a short hose that fits the water pump and another that fits the radiator, then go to a plumbing store and get a copper elbow to connect the 2 hoses. Maybe a street elbow or regular and you can get 45 or 90 bends. A flex hose is not good especially with an aluminum radiator, they can bend the neck from the pressure and generally they look like a patch job when you use them....my opinion anyway. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you have 2 different size necks, get a hose the larger size to suit the routing and a reducer fitting[s] to fit in one end to step it down, and don't let some counter jockey tell you there is no such animal, I've had to use them on a project
Bill | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | I thought about an elbow. I have heard about a reducer but have never used one. Sounds like 2 good suggestions if i can't find the right hose. I have a couple more parts stores to check out first. Thanks guys. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | You might look into Dayco #70452 lower hose it has 11/2" on eng. side and 13/4" on rad side. 14" long and the right shape. | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | That looks like it will work. I'll call around tomorrow. Thanks. | | | | | Joined: Jan 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 34 | if you have 2 different size necks, get a hose the larger size to suit the routing and a reducer fitting[s] to fit in one end to step it down, and don't let some counter jockey tell you there is no such animal, I've had to use them on a project
Bill good call I had to go to 3 parts stores to find one that could help, reducer works great | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 |  my local NAPA has a good collection of paper catalogs and some guys who know how to use them, a lot of stuff that isn't in the computer is available for unusual & non-OEM applications Bill | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | nobody had that hose. said they could order it. i went to napa and found what i think might be a better hose. i'll find the number on it and post it. but i do think that dayco hose would have worked fine. thanks. | | |
