| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Hi Gang,
I picked up a 1955 First series engine and transmission yesterday and was wondering about the transmission. The shift levers do not clamp on like what I am used to seeing on 54 and earlier transmissions ( three speed colum shift). Also there appears to be a reverse switch for a back up light (?). Does anyone know if this could be a 55 first series transmission or is it definitely something else?
Joe [IMG
1955 First Series 3100
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks to be a '67 or later Saginaw 3 speed.
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Thanks for the response Guys, I was hoping it was the original transmission but if it works OK I will use it (the fellow I bough it from said it came out of his truck and ran/shifted just fine)
Joe
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Saginaw transmissions are great . The linkage looks a bit hokie but if it works it works.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | Is there someone that sells different shift arms (what do you call them anyway??) to make the Saginaw work with the AD trucks? My guess is AD trucks never came with Saginaw transmissions.
Thanks again guys,
Joe
Oops I almost forgot to ask, will the speedometer read correctly with this Saginaw transmission ?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you're looking at making your own linkage rods by modifying whatever you have - the Saginaw started about 1968 .... and the speedo is unlikely to read correctly, although if you're lucky it could be close [rear ratio and tire size] - check it against a gps app
Bill | | |
