| | | Forums66 Topics128,162 Posts1,056,910 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 16 New Guy | | New Guy Joined: Jan 2011 Posts: 16 | I just finished off the above and thought I should share. I did search the forums and found the info a bit lean. So here is what I did.
I converted over to 12v, and shortly there after starter went out. I found a 12v starter with 9 tooth gear for my 139 tooth flywheel from Carquest. I am running the 4spd sm420 tranny with a 11" clutch. After I had the flywheel machined my new clutch went in. I got this from O'Reilly, SACH's part# K5473-01. I really didn't think much about it but I would think about changing the clutch fork and ball joint if you have everything off.
I hope this helps someone at some point. I have certainly gotten a lot of help from the Stovebolt gang.
Thanks.
Robert Greer 55 1st
