7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC), 60 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#93478 11/17/2005 2:14 AM
ok. i just got my first pre 60s truck. there were no battery cables or even a battery. my question is. how to tell if it was positive or negitive ground. and also if its a 6 or 12 volt system. i thought it was gonna be easy. :confused:
#93479 11/17/2005 5:51 AM
What is the truck? Chevy or GMC? What year?
There are lots of things that might be clues. If it has any lights check the bulbs to see if they are six or 12 volt. That's not conclusive, but its a start.
If it has a coil look for a voltage indication on the coil. You can also check the starter, generator, regulator, horn relay and other items like that to see if any are marked 12 volt.
Does it have a radio? The radio might supply more clues.
If you are trying to restore the truck, knowing what it is will get to the answer. If instead you are just trying to make it driveable, it might be easier to determine what the parts you have support, and then finish that system.
#93480 11/17/2005 6:01 AM
The first place I'd look is in the "search" feature of this board. Then I'd click on
this thread
and
this thread
#93481 11/17/2005 7:36 AM
ok. thanks. ill go nose around. its a 48 GMC 1 tonflatbed. and cant get the bulbs out without them messing up the base. this weekend ill be spending a lot of time with it. so ill look at the coil and other things
#93482 11/17/2005 7:35 PM
48 GMC would be positive ground in stock configuration.
1954 GMC De Luxe COE
#93483 11/18/2005 2:37 AM
And six volts.
