4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | I have a 46 gmc one ton and would like to remove the doors to repair the rust thru. Do you just remove the large phillips screws or does the hinge have pins you can pull? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The 46 is different from the AD as far as door removal goes. I believe you do have removable pins if that is the way you want to do it. I use that a lot on my 38 Master when I am working on the door itself. Removing the pins means the door doesn't have to be adjusted every time it is mounted.
If the pins are really tight, I use the ball joint/U joint clamp. I use a small bolt on the bottom of the pin and a socket to fit over the head at the top. | | |
