5 members (Peggy M, Bill Hanlon, carbking, baldeagle, Southerntruck), 70 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#934276 04/09/2013 1:07 PM
does anyone know if the single barrel rochester carb. on a 235 engine is the same as the carb on a 228 GMC engine? Is the bolt pattern where the carb bolts to the intake the same?
Dave
oldburbs #934285 04/09/2013 1:56 PM
What year 228?
What size GMC?
Typically, the GMC carburetor would have been a Zenith (and, maybe a Holley)?
The bolt patterns might match.
What year 235 manifold?
tclederman #934308 04/09/2013 3:34 PM
Its in a 50 GMC suburban. Just bought the 235 and it needs a carb. I thought maybe the carb on the 228 might work on the 235. Thanks for the shout-back.
Dave
oldburbs #934432 04/09/2013 10:02 PM
i belive the gmcs share carbs with 216s and early 235s. if you have a full pressure 235 ( with four bolts around the valve cover).
then the bols will be spaced out wider then your 228 zenith. so.. you can
1. get a carb for a 235,
2. ive heard of ppl fileing out the holes on the throttle body base, but i would want to ruin A good zenith.
3. swap manifolds. you need to get the stepped alignment rings. im assuming the 228 manifold fit fit you might want to investigate your self before going that route.
If i had the 228, id keep the carb to go with it, then find a 235 carb used for 60-80 bucks.
you'll need to fab a front mounting plate as well cause the 235 will be shorter.
oldburbs #934438 04/09/2013 10:10 PM
A 228 manifold will not fit a 235.
oldburbs #934517 04/10/2013 9:24 AM
good to know it dosent fit. he could use a 216 manifold on his 235 with his 228 carb right?
drew_vigil #934839 04/11/2013 12:04 PM
the 216 carb is different than the 235. bolt pattern is different. I want to use the carb thats on the 228 (GMC) and put it on the 235 intake. Bolt pattern is 2 15/16" bet the bolts that fasten carb to intake.
oldburbs #934880 04/11/2013 2:47 PM
Carburetion specialist
C Online: Content
The flange size for a 1950 Chevrolet 235 should be S.A.E. size 3, that is center to center bolt spacing of 2 15/16 inches.
G.M.C. used dozens of different carburetors on different year and application 228 engines. ALL that I have information on are ZENITH size 10 and 11.
Zenith had intermediate sizes; but both the Zenith size 10 and size 11 correspond to an S.A.E. size 2 flange which is 2 11/16 center to center.
The throttle bore on the Zenith size 11 is slightly larger than the Zenith size 10; again BOTH are 2 11/16 center to center.
The Zenith corresponding to S.A.E. size 3 would be Zenith size 12.
If you have a good G.M.C. 228 Zenith carb, perhaps you could find a Chevrolet 216 intake and use the Zenith carb.
Jon.
The Carburetor Shop
carbking #934945 04/11/2013 6:52 PM
thanks for the info. So does the 216 manifold bolt up to a 235 without any alterations? Can I use just the intake? Also, could I use the zenith size 10,11 with the 216 manifold? How do you tell the different sizes of the Zenith carbs? Appreciate the help.
DAve
oldburbs #935842 04/15/2013 8:41 AM
The 216 mani bolts up to the 235 but you have to find stepped ailment rings.
I had a 216 manifold attached to my 235 when I got it and they did not use the correct stepped rings they just had the 216 rings. That must have been a pain to put on
