4 members (Ponchogl, GRNHydra, TPR57C, stlcardinalsguy), 143 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#93413 11/08/2005 9:03 PM
Junior Member
Junior Member
How close does a horn relay need to be to the horn? or does distance not matter? and what gauge wire should be used between relay and horn?
Frank
1949 Chevy 3800
1929 Chevy International
#93414 11/08/2005 9:32 PM
Riding in the Passing Lane
It doesn,t really matter although closer is better. One horn on 12 volts 12 gauge would work. Two horns, 6 volts, or along distance use 10 gauge.
1972 Chevy c10 Cheyenne Super
#93415 11/10/2005 12:52 AM
Jim & Caroline
#93416 11/10/2005 1:38 AM
Good article, I think it is originally written for motorcycles, but who cares. But I have a question:
Do I need a relay marked 6 volt for a 6 volt truck, or does it matter?
#93417 11/10/2005 6:39 AM
I would not count on a 12 volt relay working reliably on a 6 volt truck.
I would suggest positioning the horn relay where it minimizes the length of the wire between the horn and the source of power for the horn.
Also that article referenced above is suggesting wire sizes based on a 12 volt system. Use bigger wire (lower numbered) for a 6 volt system.
#93418 11/10/2005 3:49 PM
Hey Brian
yes you should use a 6 volt relay for 6v system.
I would call a local volkswagon shop if you can not find one at the local supply house.
Jim & Caroline
