Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 111 guests, and 5 robots.
Topics128,277
Posts1,058,456
Members48,490
#934090 04/08/2013 8:37 PM
I have order the window felt kit from classic parts to put my new glass in that is being cut locally. My question is about the "Glass Setting tape" is this actually a gasket material or a tape? when i removed the frame from the glass it appeared to be more dried out rubber than a tape? Has anyone not used the tape and just used silicone instead? thanks Steve
I took my vent window to a glass shop and had them fit the glass in the frame with urethane they use, looked perfect. I had one heck of a time with the tape and yes, I tried more then one thickness, had trouble with all.
If you never tell a lie, you never need to remember what you said.
Ditto, I used the urethane as well. The tape wouldn't hold the glass, so every time you went to roll the window down it would pop out of the regulator. I wouldn't waste my time with the tape in the future as well.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
I had no problem with the tape. By the way, they sell the tape in different thicknesses.
The tape is a rubberized product. It should be a tight fit. You use oil during (to ease) installation so that the tape swells (due to the oil) and locks the glass in place. Then, if the glass is broken in the future, gasoline or similar solvent will attack the rubber tape and cause it to let go of its hold. If you use glue/sealant, clean-up to replace the glass will be difficult and time consuming.
And make sure you roll the window up all the way so it seats the glass/rubber in the channel and leave it rolled up while the rubber expands and sets.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Excellent, thank you. I was hoping to do it this weekend but tape wont arrive till monday. I scored a piece of Textured Black ABS plastic for $10 yesterday so I will be making some door panels this weekend.
How long until it is set and i can trim the rubber and clean it, took me about and hour last night to get both windows done. I had two loose spots that i trimmed some extra tape and slipped it in to double up seems to have filled the gap nicely.
thanks for the tip it worked out real well. Cleaned them up ready to install. Steve
