| | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I'm looking for the pinion bearing spacer. I have looked at Jim Carter, Obsolete Chev , Chevs of the 40s , American Classic Truck , Truck+CarShop , web sites and am unable to see the item. Can someone please direct me to a supplier who will ship outside the USA. Thanks for your time  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | nothing shows at Rock Auto, and NAPA shows just the same parts as there .... I'd say it's not around new Bill | | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | If you go to the "Links" at the top of this page there is a list of Clutch/Driveline parts suppliers. May be worth a try. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks for looking Bill, I appreciate your time.
So how do you set your truck diff up if the (consumable) parts are unavailable. There must be a trick to stretch the worn spacer for reuse. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Tom's Differentials has them. Part number EC-CS.
Bill Burmeister | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks for your suggestions guys. | | |
