2 members (Woogeroo, 1 invisible), 163 guests, and 6 robots.
Topics128,268
Posts1,058,379
Members48,485
Hi Gang,
I picked up a 1955 First series engine and transmission yesterday and was wondering about the transmission. The shift levers do not clamp on like what I am used to seeing on 54 and earlier transmissions ( three speed colum shift). Also there appears to be a reverse switch for a back up light (?). Does anyone know if this could be a 55 first series transmission or is it definitely something else?
Joe [IMG
1955 First Series 3100
Looks to be a '67 or later Saginaw 3 speed.
Bill Burmeister
I'm with Bill
My Blog
Thanks for the response Guys, I was hoping it was the original transmission but if it works OK I will use it (the fellow I bough it from said it came out of his truck and ran/shifted just fine)
Joe
Saginaw transmissions are great .
The linkage looks a bit hokie but if it works it works.
My Blog
Is there someone that sells different shift arms (what do you call them anyway??) to make the Saginaw work with the AD trucks? My guess is AD trucks never came with Saginaw transmissions.
Thanks again guys,
Joe
Oops I almost forgot to ask, will the speedometer read correctly with this Saginaw transmission ?
you're looking at making your own linkage rods by modifying whatever you have - the Saginaw started about 1968 .... and the speedo is unlikely to read correctly, although if you're lucky it could be close [rear ratio and tire size] - check it against a gps app
