0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
Junior Member
Junior Member
I have a '49 1 ton Chev flatbed that was converted to 12v in early '60's with a 12v generator and regulator. My battery is new and the last few times I've gone to start it the battery was dead. With a good volt meter how do you search around to test were that drain might be? or is this the nature of an old big truck?
Fletcher
Frank
1949 Chevy 3800
1929 Chevy International
Sounds like you have a short somewhere. Since you don't have a fusebox, just start carefully unhooking things until the drain goes away.
1954 GMC De Luxe COE
Junior Member
Junior Member
It actually does have a fuse panel. If there is a short, would the fuses blow?
Frank
1949 Chevy 3800
Frank,
This might sound stupid but one way would be to go through a process of elimination. Your voltmeter probably can also serve as a continuity tester.
Turn off your ignition key.
Disconnect your ground cable from the battery.
Connect your continuity tester between the negative post of the battery and your battery cable end.
If you get a continuity reading, you have a short somewhere.
Now, start disconnecting electrical leads one at a time. If/when you loose continuity, you found the source of the short.
Start with the leads at your fuse box (start removing fuses).
Then disconnect the generator leads to the voltage regulator. (A wild guess would be that the generator has not been polarized and current is running "backwards" when you shut off the ignition).
Many years ago, I used this technique on a VW and found a short in the electric clock, which normally runs all the time but was the only device drawing current with the ignition off. A short in the non-working clock was draining the battery very slowly.
Tim
Frank,
If you charge the battery, park the truck, and several days later return to find a dead battery, you don't need to look in any circuit that is switched...tailights, dashlights etc. Concentrate on a circuit that is energized when the truck is just sitting, the charging system, battery side of the key or ampmeter, hot side of the brake switch. Although not common, a battery can develope a shorted cell which will discharge it. Sometimes, a cursory exam of the rig will turn up a bare wire that is laying against the frame or a mechanical component.
Maybe your check engine light is stuck on. wink
Stuart.
