0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
Can anyone tell me when they started to use a 12v starter with a foot switch. Or is this a conversion to make it look like a 6v starter for appearances sake?
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
12V started with the 2nd series 55, the 235 was foot start until 1959
I'm going to jump in here...I'm very limited in my knowledge of electrical and wiring systems. My truck is '56 3100 2nd series with the foot start. It was given to me in pieces and I am rebuilding and restoring it currently. How can I tell if it is 12v or 6v? There is absolutely NO wiring at all in it.
sgoering, all 56's were 12V
Do you mean 1955-2nd series or 1956 (there was no second series 1956).
If it is 1956, it is most likely 12v. It came from the factory 12v. It is doubtful that someone would have changed it to 6v.
Does the starter and/or a generator have a metal tag on it? Is it red (12v) or black (6v). This is not "proof" because a 6v starter might have been used on a 12v truck (but, not visa versa).
Check a headlight (you might have to take it off to see if the voltage is on the back).
Ok, thanks guys! It is a '56. Not sure about the tags. I will take a look this afternoon and see what I can find out. Thanks red58 and tclederman!
