| | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 17 New Guy | | New Guy Joined: Mar 2013 Posts: 17 | im having some trouble getting my rear drums off of my 49 3800. I took the screws out of the front and tried hitting the drum around the lugs i got one to wiggle a bit but it feels to me like the brakes are holding them up. The parking brake is free and lose. Is there any way to losen the rear brakes? Can anyone help me out? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The rear brake adjusters are on the backside of the backing plate. There are two adjusters per side, one on each end of the wheel cylinder. You'll need a 5/8 socket to back them off. This procedure should be in your shop manual. | | | | | Joined: Mar 2013 Posts: 17 New Guy | | New Guy Joined: Mar 2013 Posts: 17 | Thanks ill try that i thought that was what those bolts were for | | |
