| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93041 09/29/2005 12:20 AM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | Can't get my blinkers to work, any ideas? Head lights, and stop lights work ok, but blinkers are not going blink, blink, blink!
PJP
#93042 09/29/2005 12:32 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | This is probably too simple, but have you tried a different flasher, and are you sure all of the bulbs are good.
I know, you said the headlights and stop-lights work, but how about up front? | | |
#93043 09/29/2005 12:41 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | on my 52after market.I have had the fuse to be lose in the glass, not blown, just not screwed tight enough on the twist end...and then it could be a blown fuse, or a lose bulb or as jed says a flasher. when you turn on the blinkers do they light up at all? and just not blink?..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
