4 members (Peggy M, mick53, kades51, Hotrod Lincoln), 46 guests, and 9 robots.
Topics128,012
Posts1,055,313
Members48,419
#93041 09/29/2005 12:20 AM
Can't get my blinkers to work, any ideas? Head lights, and stop lights work ok, but blinkers are not going blink, blink, blink!
PJP
#93042 09/29/2005 12:32 AM
Jed Offline
This is probably too simple, but have you tried a different flasher, and are you sure all of the bulbs are good.
I know, you said the headlights and stop-lights work, but how about up front?
#93043 09/29/2005 12:41 AM
on my 52after market.I have had the fuse to be lose in the glass, not blown, just not screwed tight enough on the twist end...and then it could be a blown fuse, or a lose bulb or as jed says a flasher. when you turn on the blinkers do they light up at all? and just not blink?..Fred
Redryder pix
My Hotrod
