2 members (Ponchogl, Shardean),
85
Mod | | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93018 09/24/2005 5:17 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | Hey guys does anyone know how many wires should go to the distributor on a '46 GMC Canuck. I tseems to me that there are two posts coming out horizontally 180 degrees apart, one I know is the positive off the coil (I think...) The other? thanks for any help | | |
#93019 09/24/2005 6:46 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I can't imagine what a second wire would do unless it was a ground strap. Is it possible you are mistaking something else as a wiring post?
The one wire I'd expect should come from the coil and connect to the points. You say its the positive off the coil, that is correct if the truck is still positive ground. If its been converted to negative ground it should be wired negative post connected to the points.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
