| | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 17 New Guy | | New Guy Joined: Oct 2008 Posts: 17 | Does anyone have a napa/autozone lower rad hose number for a 1956 GMC 100 with L6? My truck came without one autozone is not showing a lower rad hose on their computer...typical
Thanks Alex
"If you can't fix it with a hammer, you've got an electrical problem."
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | best thing to do is make a 'pattern' with a piece of stiff wire and take that with the length measurement to a parts place that has a catalog from Dayco that shows shapes and dimensions - I think you might find one, but you might also be stuck using the flexy corrugated universal type, exact pre-shaped replacements for some applications are no longer made
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Cajunhcm, I could not find a molded hose listed for the lower rad hose you are seeking, just a piece of 1 1/2" straight hose. That got me wondering if maybe the bent part was pipe originally, and it was connected to the engine by short pieces of hose and clamps, hope that helps. | | |
